3 amigos tested w/todays NY weather
Old Dec 13, 2007 | 06:38 PM
Disc02SD's Avatar
3rd Gear
Default 3 amigos tested w/todays NY weather
I had a vistor from the 3 amgios about 3 months ago. That day I pulled off my front tires and was in need of changing asap, which I did that day. The lights of course still stayed on but with todays snow fall I was able to see what was working and what wasn't. The ABS even though the light is lit works fine but the Traction Control isn't working at all and the Hill Decent I haven't test. Based on the fact that the abs is working and traction is not my first thought was speed senor but want the opinions of those with more knowledge than me. Any input would be appreciated. Thanks guy
Old Dec 13, 2007 | 07:03 PM
Default RE: 3 amigos tested w/todays NY weather
What you have described is very normal when there is no real failure of the ABS system. When there is a true failure of an ABS part the ABS won't pulsate, in your case, your ECU picked up a little glitch and when you have the codes read and cleared the lights will most likely will stay off.
For what it is worth, mine is doing the same thing right now.
Old Dec 13, 2007 | 07:50 PM
JayhawkinIdaho's Avatar
I'm in agreement with Mike just had my codes cleared and 50 miles later still fine so far.
Old Dec 14, 2007 | 05:23 PM
Disc02SD's Avatar
3rd Gear
Thanks guys... but the fact that the Traction Control isn't working as I can spin my tires on the snowy ice wouldn't that indicate a problem somewhere or would reseting the codes correct that?
Thanks again
Old Dec 14, 2007 | 05:36 PM
No, the ETC and HDC will not work when the trio is on.
Old Dec 14, 2007 | 05:59 PM
afphinfan's Avatar
I'm sure this has been discussed before but you would think that there would be some way to manually reset them by unplugging something, etc.I wish I could get a hacker to bang out a reader/reset app to run through a laptop but the programmers that work for me aren't that good ...
Old Dec 14, 2007 | 06:37 PM
Disc02SD's Avatar
3rd Gear
Okay thanks again, I will look into finding a locate shop NOT LR to reset my comp. Anyone know any in the NY 5 boros/Long Island area?
Old Dec 14, 2007 | 06:54 PM
Just call around and see if you can find a lap top type scanner like an Auto Logic scanner or something similar.
austinlandroverbill
May 28, 2015 05:57 AM
nahtanoj
ROAMING WITH FRIENDS
Jun 24, 2012 12:15 AM
adam123
Jun 26, 2011 10:15 AM
sloppyjoe
Oct 14, 2009 07:45 AM
ek5usmc
Sep 20, 2008 06:21 PM
