3 inch lift help
I ran 3.5" with a stock front driveshaft, abs lines, and brake lines, along with sway bar disconnects. The stock driveshaft was fine, but the Universal's did wear out pretty quickly due to it operating at a totally new angle. I got a stock replacement from lucky 8 and never had a problem. Brake lines were *just* long enough, so as everyone has said before me replacing those is a good idea. At full flex mine were like a banjo string. If you're only going to street drive then stockers are fine. Never had a problem with the ABS lines, but I believe I did unclip them or something from the frame.
