3 inch lift help
Old Jan 3, 2020 | 12:34 AM
dealbergaria11's Avatar
Hmmm after all this, I am thinking of switching back to the 3" lift and buy a GBR shaft with extended brake and ABS lines. Thanks a lot!
Old Jan 3, 2020 | 09:39 AM
whowa004's Avatar
I'd run RTE coils and fox shocks, new front shaft and extend brake lines/ABS lines. Pull the front support beneath front shaft and pick up an extended watts linkage
Old Jan 3, 2020 | 10:54 AM
Alex_M's Avatar
I ran 3.5" with a stock front driveshaft, abs lines, and brake lines, along with sway bar disconnects. The stock driveshaft was fine, but the Universal's did wear out pretty quickly due to it operating at a totally new angle. I got a stock replacement from lucky 8 and never had a problem. Brake lines were *just* long enough, so as everyone has said before me replacing those is a good idea. At full flex mine were like a banjo string. If you're only going to street drive then stockers are fine. Never had a problem with the ABS lines, but I believe I did unclip them or something from the frame.
LRDISCO
Jul 7, 2021 04:39 PM
satxpipe
Dec 1, 2017 01:45 PM
LRlax11
Sep 9, 2015 07:04 PM
blcp86
Jul 27, 2009 09:21 PM
mrcrptguy
Jan 21, 2009 11:27 AM
