3amigos
Old Aug 22, 2013 | 05:25 PM
Celto 4's Avatar
Default 3amigos
Hi all sorry if this a repeat :-) didn't see my post and I'm doing this on a phone out in the boonies! I got a fault code of 01 working on 3 amigos problem no other codes where do I go from here?
Old Aug 22, 2013 | 06:12 PM
ebg18t's Avatar
You fix it,
Look at the shutter valve post at the top of the forum.
Old Aug 22, 2013 | 06:18 PM
That is not an ABS fault code and you won't be able to find the codes without a 3 Amigo type scanner.
Also your drive shaft is not causing an ABS issue.
Old Aug 23, 2013 | 09:45 AM
Chrisinhouston's Avatar
How are you getting these codes? What kind of device are you using?
Old Aug 24, 2013 | 08:55 AM
Celto 4's Avatar
Good morning! Nice looking truck by the way! I bought an Autel 301 it was supposed to do all the codes from 1996 on and did fine when I was diagnosing misfires doesn't seem to want to pull anything with the three little friends though if they are in there! Thanks!
Old Aug 24, 2013 | 10:14 AM
But, I bet it doesn't handle ABS codes, not based on that fault code number you posted.
Old Aug 24, 2013 | 10:20 AM
Autel OLS301 Oil Light / Service Reset Tool
Doesn't mention anything about reading ABS codes. These codes are specific to the braking system and not the same as OBDII codes
dusty1
Jul 1, 2015 06:08 PM
