4.0/4.6 rotating Assembly
Old Apr 13, 2016 | 07:59 PM
Stu-Nyce's Avatar
Default 4.0/4.6 rotating Assembly
I know on the GEMS 4.0 engine you can preform the 4.6 crank and rod swap with 4.0 pistons and just tell the computer its a 4.6. What about the BOSCH? I have a 00 Disco 2 that i am resealing and was thinking of putting the 4.6 crank and rods in and just use the 4.0 pistons. or should i use the 4.6 pistons also? I did not know if the 4.0 pistons would be ok or not. Any advise would be great.
I plan on building the disco up.
Old Apr 13, 2016 | 11:34 PM
Joemamma1954's Avatar
From what I have read, the 4.0 pistons will give you more compression.
Old Apr 14, 2016 | 06:10 AM
drowssap's Avatar
4.6 crank and rods with 4.0 pistons is becoming a common swap with boshe also.
Old Apr 14, 2016 | 06:52 AM
Stu-Nyce's Avatar
Ok I was not sure if it would change readings enough that the ecu would adjust for it and make the swap not worth it. And if i had to do any computer swaps or flashes..
Old Apr 14, 2016 | 01:37 PM
abran's Avatar
4.0 Pistons feel like you have more power, but I am always wondering if it's just because the motor is fresh.
I guess I need to put one on a dyno.
TOM R
Mar 18, 2015 02:33 PM
dustinvonholten
Nov 23, 2010 05:08 PM
salve7
Jan 21, 2010 01:22 PM
Chrisinhouston
Nov 9, 2009 01:37 PM
mwsharb
Mar 12, 2009 09:35 AM
