4.0 into a 1994 Discovery?
Old Jun 13, 2009 | 01:45 PM
ainiguez's Avatar
Default 4.0 into a 1994 Discovery?
Can a 4.0 engine from a 1995 P38 Range Rover be swapped into a 1994 Discovery I (3.9)?
What do I need to be aware of?
It seems that there are possible headgasket problems with the 3.9, so exploring my options.
Thanks
Alfredo
Old Jun 13, 2009 | 03:36 PM
oljohnboy's Avatar
there are possible head gasket problems with the 4.0 also. is your engine not running properly? as for the swap, i do not know.
Old Jun 13, 2009 | 06:53 PM
ainiguez's Avatar
The discovery was overheating and we tried everything. Nothing seemed to work until we rodded the radiator, then the overheating seemed to stopped. I wrote on another thread that I ran it hard for a while and nothing happened.
Well, the temperature gauge has started to creep up again, and, while we don't let it go past "10 o'clock" or so, I am afraid that it will only get worse.
The 4.0 I have in a P38 that I've recently decommisioned due to excessive wear in the inside, etc. But the engine was running beautifully, not heating up at all, not consuming oil, etc. I am exploring my options and want to know if it is viable to swap the 4.0 into the Discovery.
Old Jun 13, 2009 | 08:41 PM
Yes you can do a drop in, but you will also need the ECU from the RR as the 3.9 has a distibitor and the 4.0 has electronic ignition.
Old Jun 14, 2009 | 12:06 AM
redhotbuzz's Avatar
Doo It
Rover5150
Nov 28, 2007 09:57 AM
Rover5150
Nov 26, 2007 06:09 PM
jdmikey
Feb 23, 2006 03:33 AM
Bene
Nov 6, 2005 08:41 PM
igorYU
May 20, 2005 01:05 AM
