4:11 drive train
#23
#24
#25
Zack I think I am going to follow your lead and go ARB or Ashcroft lockers front and rear. Did you keep the ring and pinion stock or go 4.11? HD Axles are on my list as well. What would the complete ideal list look like for someone doing this? Mine is on 33s with RTE 3inch lift as well.
thanks
David Frankel
#26
The Cove where conclave is held has some crazy trails no doubt!
Went with 4.11 GBR gears, reverse cut fronts for a little extra strength. Ashcroft air lockers and ashcroft HD rear axles(fronts will come with time, I don't like the design Ashcroft has currently). High output ARB air compressor, comes with a wiring harness for the air locker solenoids so it's pretty easy to hook up.
Air lockers are just so much more superior to any other type of differential, the ability to drive without difference until you need to get out of a situation.
#27
What is the design issue with Ashcroft front HD axles?
thanks
David
#28
1) can't install the front shafts with the CV boot on, so you have to install that inside the "knuckle"
2) the stock CV boot they give you is junk(apparently) and apparently there's a replacement you can get for pretty cheap.
3) after several hundred miles or so you have to remove the shafts and then polish them or something? Per Justin at Lucky8.
#29
DiscoJon
07-14-2019 01:51 PM
