4.6 Cruciform (Crucifix) Seals
Old Apr 17, 2021 | 05:31 PM
Shiftonthefly1's Avatar
Default 4.6 Cruciform (Crucifix) Seals
I'm at the point of finishing my engine and I elected to change out my rear main seal and the Crucifix Seals. Cruciform Seals as the RAVE calls them. I found a couple incomplete threads here by one particularly angry guy but never heard the end solution.
Here's my situation. I've got the rear most main cap out and the seals installed. As I understand the manual calls for a "globule" of sealant in this spot as I have applied it. As you can see from the pics, this seal seems to poke not only upwards (unsure if I'm supposed to trim that flush) and it protrudes outward from the cap (meaning it's thickness).
This is how it looks when I apply pressure gently w a clamp. The seal pops even more upwards. If this is installed I would never be able to "trim the excess" as the manual states. So I assume that line is referring to the oil pan side of the cap.
When I proceed to try and install this cap, that top part of the seal is stopping the cap from going into the block. Should I trim here? Or am I missing something?
Old Apr 17, 2021 | 07:01 PM
Extinct's Avatar
Use a putty knife to get it in to the block, tap it down and torque it, then trim the excess.
Old Apr 17, 2021 | 11:24 PM
That's a great idea. So leave the part sticking up at the top?
Old Apr 18, 2021 | 05:48 AM
Extinct's Avatar
Yeah. You can pm me if want and I facetime while you do it.
Sixpack577
May 9, 2023 09:36 PM
Papag1313
Jan 13, 2022 09:36 AM
Sixpack577
Jun 17, 2018 08:57 PM
Jwehking
Nov 25, 2017 11:13 AM
0304Disco
Mar 1, 2012 07:49 AM
