4.6 front cover on 4.0
Old Jan 26, 2025 | 12:13 PM
miron's Avatar
Default 4.6 front cover on 4.0
Hello,
I'm about to start rebuilding my old 4.0. I have a 03 4.6 front cover that I'd like to use. I can't find any definitive answer as to whether these are interchangeable. The only thing that someone wrote is that 4.6 is missing parts for the oil cooler bypass, though after taking them apart as much as I can, it seems that the 4.6 has all the same guts - at least as far as I can see. Can anyone advise?
Thank you
Old Jan 26, 2025 | 12:43 PM
PickleRick's Avatar
I asked this a year or so ago and never got an answer. Unfortunately my only 4.6 cover was destroyed by a thrown timing chain.
My spare 4.0 cover fit on the 4.6 block without issue leading me to believe there would be no issue there however I never ran it, I instead put the 4.6 internals into a 4.0 block.
Old Jan 26, 2025 | 12:45 PM
PickleRick's Avatar
I asked this a year or so ago and never got a solid yes or no answer. Unfortunately my only 4.6 cover was destroyed by a thrown timing chain.
It appears the only difference is the relief for the oil cooler.
Old Jan 26, 2025 | 01:01 PM
miron's Avatar
I could swap the internals, but as much as I try I can't get the recessed caps that block the, let's call it "tubes" out of the casting.
Old Jan 26, 2025 | 03:44 PM
PickleRick's Avatar
In all honesty, I'd run the oil cooler if I had all the parts. Otherwise I'd forget the cooler. The only way I see the cooler being an advantage to these engine is if you spend tons of time at idle all summer with the AC blasting (construction company foreman) or tow heavy.
PickleRick
Jun 3, 2025 08:47 AM
94svt50
Jan 30, 2025 07:40 AM
PickleRick
Oct 28, 2024 08:44 PM
wjsj69
Jun 18, 2018 12:23 PM
ImQuattro
Sep 26, 2014 11:48 AM
