4.6 and SAI?
You can get 4.6 engine with and with out secondary air, depending on the state and the emission standards that needed to be met.
I had a long conversation with some one resently and if you swap out, you have to also replace one other component other then the ECU, if I remember right I believe it is the Body ECU, I can check and see if you get that far.
john65b
May 16, 2014 06:06 AM
