4 wheel drive ?
Old Jun 21, 2007 | 06:49 AM
technoferret's Avatar
3rd Gear
Default 4 wheel drive ?
hi i'm new to the forum and just bought a disco td5 2001, is it permanent 4 wheel drive or just 4 wheel when low range selected ?
might sound a stupid question but i don't know.
cheers
Craig
Old Jun 21, 2007 | 07:05 AM
Landzu's Avatar
Default RE: 4 wheel drive ?
It has permanent four wheel drive.
And you had to rubit in that you have a diesel , wish LR would have sent
the diesels to theU.S. Welcome to LRF
Old Jun 21, 2007 | 10:03 AM
So yes, it is in 4wheel drive both in High and Low range. Also being you have a 2001, you might also have a locking t/case, CDL, which is a hugh pluys if you really like to get out and play.
Mike
Old Jul 21, 2007 | 10:24 AM
3rd Gear
thanks for reply, sorry for this late reply, had lost my login info.
cheers
Craig
Old Jul 21, 2007 | 05:52 PM
Adz's Avatar
Adz
Agree with Mike - the locking T-box is, IMHO, better than the traction control fitted to the later ones. Where in the UK are you Craig? Got a bunch of us going playing on Salisbury plain 26th August if you can make it?
Old Jul 22, 2007 | 12:12 PM
3rd Gear
hi adz
i'm just outside nottingham, i have the traction control version with ace cornering hydraulics.
have got the workshop manuals on cd now so looking through it to see whats what.
Old Jul 22, 2007 | 12:43 PM
Adz's Avatar
Adz
Heard about this recently, apparently all isn't lost if you've got the TC and ACE - some of the early TC equiped ones still had the internals for the locking t-box, just not the external lever and linkage. You can, if you've got the right t-box (not saying yours is or isn't, just might be) retro fit the linkage and lever and have the best of both worlds.
Pity you're as far North as Nottingham, it's a bit of a long bike ride just for a day out really. I'll let you know if we come up country at all
Cheers,
Old Jan 23, 2011 | 07:09 AM
buck1x's Avatar
Default 4 wheel high question
I may have nothing wrong. On ice, low range, 1999 Discovery II, sudden acceleration will spin the front and rear wheels. High range only the front spin. Shouldn't the rear try also? Sudden braking on ice slides the wheels without the ABS shudder I am used to with other vehicles. Does this sound normal for the vehicle?
The high to low range selector was stuck in high but it seemed to be just never used. Once I got it to work, it is improving each time. Will clean and lube and sure to improve.
I am new to Rovers but not uncomfortable with repairs. Did the head gaskets, found the hose vent issue already.
Old Jan 23, 2011 | 07:52 AM
hilltoppersx's Avatar
start a new thread if you have questions.
DiscoJon
Jul 14, 2019 01:51 PM
TripleThreat
Apr 12, 2011 08:58 AM
BENROVERN
Nov 5, 2007 09:19 AM
Randy P
Sep 27, 2007 08:27 AM
bryanjess
Nov 10, 2005 01:03 AM
