439-180 thermo doesn't fit '04 DII?
At 116K, I'm getting ready for the 120 service and I'll be putting in a new thermo, etc....
Why does Amazon say it "This product does not fit your 2004 Land Rover Discovery?" Amazon isn't exactly a parts specialist, so can I assume that's incorrect and order it?
-Anthony
-Anthony
It's wrong. Mine fits perfect. If it fits 99-02, it fits 03-04. However the one i actually received in the mail is a lighter color than the one the picture.Motorad 439-180 180f/82c Thermostat | eBay
I just switched to that tstat, and it has royally screwed my truck. Check this thread: https://landroverforums.com/forum/sh...ad.php?t=52494. I would order the gray 180 tstat from either BP Utah or lucky8. Just my .02.
on
Amazon states that cause it is true, that is not the actual t/stat made for a D2, it was designed for a diesel and other 4 cylinder engines, does it work, oh yes.
Are you currently over heating is so the t/stat won't be the total cure. At your mileage, your radiator is plugging up and can not be cleaned out, a replacement is always recommended for over heating along with a t/stat.
As for your service, might want to look at my major service list posted at the top of this section cause you have left out a number of items from your list that should also be done.
I just switched to that tstat, and it has royally screwed my truck. Check this thread: Help Please - Land Rover Forums - Land Rover Enthusiast Forum. I would order the gray 180 tstat from either BP Utah or lucky8. Just my .02.
-Anthony
cosmiccharlie
06-05-2013 10:09 PM
