439-180 thermo doesn't fit '04 DII?
Old Sep 7, 2012 | 10:04 AM
Antmen's Avatar
Default 439-180 thermo doesn't fit '04 DII?
At 116K, I'm getting ready for the 120 service and I'll be putting in a new thermo, etc....
Why does Amazon say it "This product does not fit your 2004 Land Rover Discovery?" Amazon isn't exactly a parts specialist, so can I assume that's incorrect and order it?
Motorad 439-180 Thermostat : Amazon.com : Automotive Motorad 439-180 Thermostat : Amazon.com : Automotive
-Anthony
Old Sep 7, 2012 | 10:23 AM
DiscoRover007's Avatar
It's wrong. Mine fits perfect. If it fits 99-02, it fits 03-04. However the one i actually received in the mail is a lighter color than the one the picture.Motorad 439-180 180f/82c Thermostat | eBay
Old Sep 7, 2012 | 10:29 AM
lr2001silver's Avatar
Banned
Mine was also lighter in color like almost manila. It did say motorad on it but my temps were colder before i made the change.
Old Sep 7, 2012 | 10:57 AM
Antmen's Avatar
Thanks, guys. Trying to get everything ready and on hand before the cold sneaks up on us in the Northeast. Working on the truck in the cold is not fun.
Old Sep 7, 2012 | 11:11 AM
willrok13's Avatar
I just switched to that tstat, and it has royally screwed my truck. Check this thread: https://landroverforums.com/forum/sh...ad.php?t=52494. I would order the gray 180 tstat from either BP Utah or lucky8. Just my .02.
Amazon states that cause it is true, that is not the actual t/stat made for a D2, it was designed for a diesel and other 4 cylinder engines, does it work, oh yes.
Are you currently over heating is so the t/stat won't be the total cure. At your mileage, your radiator is plugging up and can not be cleaned out, a replacement is always recommended for over heating along with a t/stat.
As for your service, might want to look at my major service list posted at the top of this section cause you have left out a number of items from your list that should also be done.
Old Sep 7, 2012 | 11:32 AM
04duxlr's Avatar
I recently installed that t-stat in my '04, and it dropped temps around 10 degrees across the board.
Old Sep 7, 2012 | 12:56 PM
Banned
This thermostat is junk, my temps went up a few degrees after the change.
Old Sep 7, 2012 | 12:57 PM
Antmen's Avatar
Originally Posted by willrok13
I just switched to that tstat, and it has royally screwed my truck. Check this thread: Help Please - Land Rover Forums - Land Rover Enthusiast Forum. I would order the gray 180 tstat from either BP Utah or lucky8. Just my .02.
Will check it out... thanks for the heads up!
Mike, my car runs like a dream, man. No issues at all. I'm just going to do the major service due to the mileage I have... it's just time. Your list is what I will be going through, but this post was specifically about just that particular thermo I linked to.
-Anthony
G Reeves
Jul 31, 2014 09:52 AM
cosmiccharlie
Jun 5, 2013 10:09 PM
jhill15
Jan 18, 2013 12:13 PM
MC04DII
Dec 5, 2012 10:14 AM
Spencerfitch
Oct 30, 2012 07:14 PM
