45 K Service
Old Nov 6, 2007 | 02:36 PM
99XJ's Avatar
Default 45 K Service
I've seen DiscoMike's 60K service list floating around around the forum, anybody have a 45K service recommendation?
Old Nov 6, 2007 | 03:38 PM
Default RE: 45 K Service
What year truck and how many miles on it?
Old Nov 6, 2007 | 07:41 PM
99XJ's Avatar
Whoops, sorry about that, needto update my signature. '03 SE7 currently ~43K and climbing fast. . .
Old Nov 6, 2007 | 07:58 PM
No problem. If you had the 30K done then all you need besides oil and filter change would be a serpentine belt and a full inspection of brakes, hoses all that stuff along with a good bottle of gas additive to clean the injectors.
This should be spelled out in your owners manual and covered by Rover if you are still in warranty.
Old Feb 12, 2009 | 11:09 AM
MrIgotNoMoney's Avatar
5th Gear
Hello
Anybody have a link to DiscoMikes 60 k service ?
thanks bob
Old Feb 12, 2009 | 11:38 AM
DiscoRom's Avatar
Mods please put Mike's updated 60K service checklist at TOP of threads, permanently.
Thanks.
Old Feb 12, 2009 | 02:23 PM
ORIGINAL: MrIgotNoMoney
Hello
thanks bob
1 Oil filter, K&N 3001 or Mobil 1- 301
1 Factory air filter
6 Qts. of engine oil
2 feet of 3/16th vacuum tube
2 feet of 5/16th vacuum tube
12 Qts. of ATF
7 Qts. of 80/90W synthetic gear oil, 85W/140 for HD use
3 Pints of synthetic DOT 4 Brake fluid
2 Qts of synthetic Power steering fluid
2 Gallons of OAT, orange coolant, also called DexCool
1 Bottle of Lucas Power Steering additive
1 Bottle of Lucas Transmission additive
1 Can of Spray Carb. Spray
1 Can Of Brake cleaner
8 Spark Plugs, I use Bosch Platinum Plus 4's
1 Set of Magnacor 8mm plug wires
1 Serpentine belt
2 Bottles of SeaFoam gas additive
1 T/Stat
1 bottle of WaterWetter or Purple Ice
Hoses and belts, as necessary
60,000 Mile Service or Major Service for High Mileage Used Vehicle just purchased
Bleed the brakes
Flush and change the power steering fluid adding one bottle of additive
Service the tranny adding one bottle of additive
Change the coolant and t/stat
Do an engine flush before changing the oil
Do an induction cleaning
Clean the throttle body
Add fuel additive to full gas tank
Change both of the diffs fluid
Change the t/case oil
Replace the plugs and wires
Replace the air filter
Lube all the drive shaft grease fitting including the 2 slip shafts
Do full inspection of brakes, hoses, bushings etc.
Hopefully I didn't leave anything out.
kcferna
Jul 7, 2009 08:33 AM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
DaveFan782
Feb 12, 2005 11:37 PM
mr2xxx
Dec 26, 2004 11:43 PM
JA-NH
Jul 31, 2004 02:13 AM
