4L on the transfer case question
Old Feb 22, 2008 | 12:07 AM
microbc's Avatar
Default 4L on the transfer case question
HI,
Can anyone tell me if there should be any indicator on the dash when I shift into 4L? I have a 2000 DiscoII and it runs great, no check engine or 3 amigos or anything. When I put it in 4L I don't see any light on the dash to indicate that it is in low range.
It is going into low and seems to operate fine.
Sorry for such a basic question but I couldn't find the answer when I searched the forums.
Thanks,
Art
Old Feb 22, 2008 | 08:13 AM
Default RE: 4L on the transfer case question
No, there is no light, but however there is a ringing sound once you shift out of hi that will only go off once you are in low.
Are you arware that on your 2000 you can also set up the t/case so it is locked giving you about 50% more traction?
Old Feb 22, 2008 | 05:37 PM
microbc's Avatar
Hi Mike,
Thanks for the quick reply. What rining sound are you referring to? Not sure if I ever heard it. As far as the diff lock, I am aware of it and I have downloaded some plans to make a lever that will be accessible from outside the truck (I can't afford the mechanism from a D1 or newer D2).
Thanks!
Art
Old Feb 22, 2008 | 05:41 PM
Just go out and put both your tranny and t/case in neutral and you'll hear it.
I saw a D1 linkage today for $100 if you are interested.
Old Feb 24, 2008 | 09:58 PM
microbc's Avatar
Hi Mike,
I would like info on the D1 linkage you saw for $100.00. I looked at the procedure for installing that and it doesn't look too bad.
Thanks,
Art
Old Feb 25, 2008 | 07:12 AM
It was too good a deal and is sold, but here is a site that has them at $159 which is still good,
http://www.roverlandparts.com/index....S&Category=347
jrkstore43
Mar 2, 2009 08:27 AM
xb70valkarye
Feb 19, 2009 02:35 AM
dms98e
Jul 10, 2008 05:04 PM
NiteTrain
Jul 8, 2008 08:19 PM
Belaou
Sep 9, 2007 08:44 AM
