4x4 Hack: Using Your Emergency Brake As a Diff Lock
Old Jul 24, 2017 | 04:59 AM
OffroadFrance's Avatar
Originally Posted by mollusc
If your front shaft goes out, your transmission is probably going with it and you're not going anywhere...
X1 ..............
Old Jul 24, 2017 | 09:35 AM
Alex_M's Avatar
Originally Posted by Friday Night Disco
Crap and I just spent all that money on a CDL....
Don't feel too bad. This will only work if its one of the rear wheels that's spinning which is typically not going to be the case.
Old Jul 24, 2017 | 05:50 PM
No Doubt's Avatar
Talking
Ha!
Factory workshop manual http://landroverresource.com/docs/D2...hop_Manual.pdf says 70/30 front/rear weight distribution.
You've got that heavy motor, front axle, transmission, and transfer case all up front weighing on your front wheels.
That makes it really easy to spin your rear 2 wheels on your Disco!
Old Jul 24, 2017 | 05:57 PM
KingKoopa's Avatar
Originally Posted by No Doubt
Ha!
Got it backwards, rear of a disco 2 is heavier than front.
Old Jul 24, 2017 | 06:44 PM
No Doubt's Avatar
How?!
Old Jul 24, 2017 | 07:48 PM
KingKoopa's Avatar
Just how the distribution turned out.
Light motor, centralized tranny and transfer case, huge steel body with ridiculous overhang beyond rear centerline.
Hence stiffer rear spring rate and higher recommended rear tire pressure.
Old Feb 2, 2020 | 04:06 PM
BierNut's Avatar
Old thread, the 95 D1 5 spd w/4.6 I own is rear heavy biased like 52% rear vs 48% front I recall, this while parked empty no passengers or gear in the rear.
Stabbing the foot brake will stop any spinning wheel, a quick stab without causing stalling w/5 spd vs torque converter being below stall speed allowing converter slippage, adding throttle you can cheat a little.
Even with CDL locked you can get into trouble and stuck with open diffs at both ends, your now STUCK STUCK a little deeper and worse off that's about all. Locking CDL with locking diffs now your talking provided you have the horsepower especially torque. Talking torque at low rpm's doing good vs an engine you have to rev up before torque enters into the picture then spinning wheels madly digging youself into deeper ruts. Winch time......~~=o&o>.......
cornbreadj
Dec 27, 2014 07:50 PM
fanatic516
Jun 3, 2013 04:44 PM
LR4LIFE
Nov 6, 2007 10:23 PM
s4lex
Sep 6, 2007 06:11 AM
