Is 5/8ths deflection on timing chain too much?
Old Dec 31, 2009 | 10:39 PM
DooDer's Avatar
Default Is 5/8ths deflection on timing chain too much?
Got the timing chain cover off and noticed that there was 5/8ths deflection on the timing chain on the right side while the left side was taught.
Time to replace the chain and gears?
Skanks!
Old Jan 1, 2010 | 09:17 AM
Year and mileage?
Old Jan 1, 2010 | 12:14 PM
DooDer's Avatar
2004 with 80k.
Old Jan 1, 2010 | 01:24 PM
Rovin4life's Avatar
no chance in hell, on a 2004 the most you need is head job and frt timing cover, sometimes a rear main seal but thats if you manage to let your pcv system clog up and blow out the intake gasket. kinda cool to see to.
goes from concave to convex.
Old Jan 1, 2010 | 02:26 PM
200K is the normal time for a new chain.
Do consider having your front drive shaft rebuilt or replaced if it has not been done yet.
Check and see how many grease fittings are on the front shaft, 1 means it needs replacement 3, it has already been done. Not dealing with this can cost you a tranny.
A5scott
Jul 11, 2015 07:25 PM
Martin Rodriguez
Feb 25, 2014 08:55 PM
discofrost
Apr 2, 2012 05:32 PM
Kraftyz51
Oct 21, 2007 10:25 AM
tap121
Apr 10, 2007 07:35 PM
