5 speed question
Old Sep 17, 2018 | 03:16 AM
MyIQisLow's Avatar
Default 5 speed question
I was perusing the local junkyard, and came across a '94 (I think) disco, with a 3.9, and a standard. Would this 5 speed be able to be swapped into my 2003 with a 4.6? Would it be able to handle the additional hp, and torque? Is it a bad idea?
Old Sep 17, 2018 | 03:58 AM
mollusc's Avatar
Not sure, but if it's an R380 then it is documented to fit. The whole process is outlined in this thread: https://landroverforums.com/forum/di...al-swap-79203/
Old Sep 17, 2018 | 02:13 PM
DavC's Avatar
R380 was made for the buick 215 series V8s, 380 was the Newton-meter spec it was built to handle.
You will need all the ancillaries, and don't forget to get rid of the interlock solenoid on your transfer case, the manuals don't use those.
the 4.6 is only 220 hp, 280 lb/ft new? that torque value is nearly 380 so its up there. If you drive it like a normal person it should be fine.
Old Sep 17, 2018 | 06:22 PM
MyIQisLow's Avatar
Awesome. Thanks for all the info. That thread is perfect. If I decide to go for it, I will make sure I have more expertise than my own helping me. My Dad is ALWAYS up for this kind of ingenuity. I could tackle it by myself, but tinkering is always funner with someone to b.s. with.
Old Sep 17, 2018 | 08:08 PM
robertf's Avatar
You will need a newer flywheel, 94 will not have the features machined into it for the crank sensor
Old Sep 17, 2018 | 10:04 PM
mollusc's Avatar
All the details like that are in the thread I linked to earlier.
Old Sep 17, 2018 | 10:20 PM
robertf's Avatar
good deal. Probably should lock this thread
Yugo
Sep 9, 2017 10:26 PM
Thatguy
Oct 29, 2015 07:46 AM
Kennyr996
Mar 1, 2009 08:48 PM
pilsner
Dec 7, 2008 10:05 PM
ajh
Oct 31, 2007 10:17 AM
