50,000 mile maintenace
Old May 23, 2008 | 01:02 PM
ZAL's Avatar
ZAL
3rd Gear
Default 50,000 mile maintenace
I have an '02 Disco with 51,000 miles. I lost the manual & maintenance schedule. Anyone have any advice on what maintenance I need? Any advice on where to get a copy of manual and maintenance schedule? Is it necessary to go to a Land Rover dealer for maintenance? Any reply is much appreciated.
Old May 23, 2008 | 08:07 PM
Default RE: 50,000 mile maintenace
No you do not need to go to the dealer.
You need the coolant flushed, the transmission filter and fluid changed and the brake fluid changed. You also need to change the fluid in both the front and rear differentials and the transfer case.
As far as finding a manual look for the Rave CD. You can find the maintaince schedule at www.edmunds.com.
Old May 23, 2008 | 08:13 PM
polar's Avatar
You need the RAVE CD down load. Do a search. It will have all the info you need.
Old May 23, 2008 | 08:19 PM
roverguy7's Avatar
your next major service is at 60. factory services are every 7500 miles, the 52,500 service is nothing much more then an oil change, but you want to check your rubber breather hoses on either side of the intake, they start to wear out and get soft at around 50
Old May 23, 2008 | 08:26 PM
What roverguy7 is saying is true, however, LR recommends flushing the coolant every 45,000 miles or 36 months, whichever is sooner and the brake fluid every 24 months regardless of mile's.
I find it is easier to do driveline maintance at a easy to remember schedule, such as every 50,000 miles. So you do the driveline service at 50k, then 100k, then 150k so on and so on. Much easier to remember than 60k, 120k, 180? 200?, you get my point.
Old Jun 5, 2008 | 02:34 PM
ZAL's Avatar
ZAL
3rd Gear
Thank you all for your kind reccommendations.
Old Jun 5, 2008 | 04:34 PM
What was the last service done?
How often do you have your oil changed?
Just keep the fluid topped off and change the oil every 3000 miles until you are ready to do the 60,000.
Old Jun 6, 2008 | 12:19 PM
ZAL's Avatar
ZAL
3rd Gear
Thanks for the advice.
I change theoil every 3000 miles but I have not been so dilligent with other maintenance.
Old Jun 6, 2008 | 02:47 PM
You better start doing the services, it is alot cheaper to service it then repair it later.
wisconsinoverlander
Sep 21, 2012 11:23 AM
marlymarl
Aug 20, 2008 11:33 AM
anthonyb
Jul 24, 2006 01:21 PM
triggersd
Apr 27, 2006 08:15 PM
VB_Rover
Jun 9, 2005 12:49 AM
