6 codes and mechanic keeps throwing parts at truck!
Since you didn't find anything with the smoke test I would move on to fuel pressure test. Test the Fuel pressure to make sure it is up to spec then watch the pressure after you turn off the engine and see if it drops. If that checks out then maybe do a good injector cleaning (the good kind of cleaning at the fuel rail not just the can you dump in the gas tank).
A couple other things to consider.
1) You said your buddy messed with the computer settings and it really started running rough after that. Perhaps you should look closer at what exactly was adjusted.
2) He installed new lifters on an old cam. Did he do a valve job/ adjustment also?
3) He replaced the oil pump so he had the front cover off. Did he have the timing chain off at all? If so did he get it set back at TDC correctly?
Why would I cut up new o2 sensors? I want to fix the problem not bandaid it. And yes I did the smoke test. Worked great by the way and there was no leak. I held that tube shut for about 5 min and the glove stayed inflated until I unkinked my rubber hose I used for the test.
Unplug the passenger front o2 and look in the harness side plug. Pull the white cap out and you will notice it's soaked in oil in there. That is passing voltage from the heater circuit to the sensor circuit and flipping the ecu out. The only r3al way to fix it is to cut the plugs off and splice the wires together.
adolfojbonilla
08-12-2015 01:19 PM
EHGIII
03-17-2015 10:33 AM
Snafu / Disco Fries
08-20-2013 09:05 AM
