#6 plug loose
Old Apr 5, 2010 | 09:12 AM
jrm123180's Avatar
Default #6 plug loose
My #6 plug is loose and I'm unable to tighten it. I"m guessing that the pervious spaz that worked on the vehicle cross threaded the plug as it was tight coming out. Any suggestions on this or am I F*ed?
Old Apr 5, 2010 | 09:15 AM
okdiscoguy's Avatar
They make new thread pieces you can screw in. Google helicoil. You can run an oversized tap through and insert the helicoil in. Best repair for this IMHO. Pretty sure they are 14MM, so something like this should work:
http://www.jcwhitney.com/spark-plug-...29&zmap=14267G
Old Apr 5, 2010 | 10:12 AM
That is about your only options. In the future use some anti-sieze on the threads to prevent this from happening.
Old Apr 5, 2010 | 12:58 PM
jrm123180's Avatar
thanks, went to pepboys and got a kit just for this....hope it's as easy as it looks.
primey
Oct 26, 2011 07:24 PM
jordamf
Sep 14, 2010 07:34 PM
robot808
Nov 18, 2009 11:10 PM
Disco Alan
Apr 21, 2009 06:22 PM
