7mm v 8mm wires
7mm v 8mm wires
i just went to Atlantic British to order 8mm magnecor wires (as per everyone heres suggestion) and was told they don't stock OR recommend using them.
the reason given is that they do not fit inside the wire holder correctly and can pinch the wire.
surely if the 7mm are good enough for Mr landrover (corp) why do people here INSIST on changing to 8mm. I'm not looking for any power increase. just want to replace, as the current wires are not in great shape.
Can you shed some light on this for me?
I have magnecore 8mm and they fit fine in the holders. I just used a little dieletic grease and they snapped right in. They have been installed for 1.5 years and been great. I double checked the original box and and they are the 8mm for sure. I have a 2003 maybe the holders on newer models are larger...just a guess.
