7mm v 8mm wires
I've switched from Magnecore to Kingsborne, 1/2 the price for good wires.
They also sell wire separators that 8mm fit well in.
Wires
http://www.kingsbornewires.com/produ...&categoryId=38
Separators
http://www.kingsbornewires.com/categ...?categoryId=88
WOW!!...even less than half....$35 for 8mm.
are they working well for you?
it says they have screw on coil connectors...do the LR wires screw on or push on?...i know they have "ridges" , i thought this was for a good fit...not sure if i should have "screwed" them on.
thanks muchly for the link...i may go with these....$ is an important factor for me now.....in the "ole days" i just used to buy the most expensive...DUH!
I have had the Kingsborne 8mm and the STI 7mm honestly I prefer the STI I noticed that the Kings had given me an odd radio wine... The 1mm difference is not enough to matter in our motors... Now on my Corvette I run 10.5 Taylors but that is a high compression fire breathing bad ***... The Rover is just a daily driver with the capabilities to do much more... lol...
On the 8mm point also I work for a Rover repair shop in Denver and we have had many trucks come in with 8mm wires that for some reason or another are arcing and I have never seen a 7mm wire come in with that issue... Actually we have swapped wires on many Rovers from the 8mm to the 7mm just testing because there is a missfire and that has solved many of those customers problems... Just something to think about...
![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
Many many many many people have done a complete tune up on their DII and afterwards have a mis fire that cannot be solved.
They always leave the forum to never be heard from again after replacing the coils and having the problem remain.
