88,888 miles and joined the ticking club
There are lots of things that cause ticking. It is helpful to "hear" where the tick is louder, with a mechanic's stethoscope or a broom handle held against the valve cover or other areas, with your ear pressed to the far end. There have been write ups on the tick related to SAI, cracked oil pump, lifter and valve train noise, and the dreaded slipped liners.
Oil pump tests involve removing oil pressure switch, attach a mecjhanical guage (rent from auto parts store), and record readings at col (idle and 2500 rpm) and war (idle and 2500 rpm).
If you DIY, this can be done at home. If you prefer a mechanic, a good indy shop can do this. Dealer would be last choice due to very high prices. However, some prefer to maintain by open checkbook.
As far as it going away by itself, no that will require some assiatnce from your wallet.
If you are planing to keep the truck......
You might want to do what I am doing right now (in the garage working on the truck) and change all the gaskets, oil pump (mine was cracked too), water pump, timing chain and sprockets, pulleys, serpentine belt, etc.... So far I am under $1000 (ordered all the parts from Atlantic British) and hopefully will have a reliable truck again once everything is together. My mileage is 84,000 miles.
Good luck with whatever you decide to do but don't risk it!
Cheers!
Cheers!
Cheers!
Cheers!
150,000 miles ok, but not 85,000.
You are right Spike. I (and the rest of us) should be mad. But however......warranty is expired. We are all SOL. Land Rover will do nothing about it. As soon as I found out about "oil pump" issues a few years back, I called Windsor, Ontario dealer and they told me that my VIN is out of the range and that there is nothing to be worried about. Well.....they gonna get my old oil pump through their window soon .
To be honest....I was happy that I found mine to be cracked. Simply by doing preventative maintenance,I got lucky and found it before it did any serious damage.
Don't get me wrong.....I am fuming that I have to deal with this, but like I said....I caught it in time.
$1000 and a week of work could have cost me 4 times as much if I haven't caught it in time. Plus now......a lot of other things are changed and I have a reliable truck once again (hoping it starts once I am done putting it all together )
I took my losses and moved on.
WELCOME TO THE CLUB. I am in that club, again... I have a D I 1995... She ticks but thats how she will stay. I did a oil pump, timing chain +sprockets, lifters, rockershafts, pushrods and she didn't tick....... wellllllllllllllllllllllll 200 miles later tick tick tick tick.... Oil psi is 43 at 2500 rpm and 20 at idle.. She has oil so she will tick until she dies. THEN I will rebuild the engine, again. I should of done a crankshaft but I didn't know that I should of.. I think thats what the issue is, there is a nitch in the crank so it slips and causes the ticking. Mine also sounds like it is right below the oil pan, but when you take a stethoscope to it you can tell its coming from the second lifter on the drivers side. I figure the damage thats done has been done and driving her with the tick isn't going to help but will it hurt? Maybe but if the cam is bad the cam is bad... Just my view. I figure its easier for the motor to crash and burn then to sit for hours and hours and put parts into it just to realize that what you did wasn't the issue. AGREE?
