95 D1 wont start
95 D1 wont start
I have a 95 D1 (3.9) 92000 miles, it has been running fine with no problems. My wife went out to start it this morning and it will turn over fine but no start. I have fuel pressure and spark, it doesnt seem like the injectors are actuating. On my powerstroke deisel the cam positioning sensor went bad and had the the same problem. After reading the rave it said the timing would just change if this sensor went bad. Any ideas? I checked all of the obvious things such as: fuses, fuel pressure, spark, battery. Also where is the CPS on this model?
Thanks for any help
Thanks for any help
First lets reset your inertia switch, black button on the firewall.
Open up your ECU and look for cracked solder joints, re-solder them with a pencil soldering iron or a low heat soldering gun.
It may have water in it to, if so it needs to be aired out.
Otherwise you can get a used ECU for pretty cheap.
First, Thank you for the help, forums are the best. The inertia switch is good I reset it and checked it with my meter. I have plenty of fuel pressure to the shrader valve on the fuel rail. I am having a hard time checking voltage to the injectors as they fire. I checked spark and that looked good. I noticed my relays are in the passenger footwell and not under the hood. Would the ECU be in the same area?
