95 disco 70k miles hesitation
Old Dec 20, 2007 | 06:37 AM
benflynn's Avatar
Default 95 disco 70k miles hesitation
I just put new HG on my disco,new plugsand chased down a vac leak, now i have a hesitation, worse w/cold, the plugs were black, and if you stall it in gear it will not fire back up for a min
how can i check the clt temp sensor to the ecu, and fuel temp sensor?
also, are there any ls1 swapp kits avail?
Old Dec 20, 2007 | 12:22 PM
98roverguy's Avatar
Default RE: 95 disco 70k miles hesitation
Sounds like your running rich. Do you have any codes? Check engine light on?
Old Dec 21, 2007 | 09:33 AM
benflynn's Avatar
no codes, but i think it is rich, mpg is way bad, and idle searches a bit
Old Dec 21, 2007 | 11:57 AM
What spark plugs are you using, what gap, and have you ever replaced your plug wires?
unning rich can still be because of a vaccum leak, may want to search farther.
Old Dec 21, 2007 | 12:18 PM
benflynn's Avatar
bpr6es(my race volvo runs bpr8es) gapped at 32, brand new
is vac leak will make it run rich, i bet that is my problem, i bet it is the booster
Old Dec 21, 2007 | 01:01 PM
You might want to check, I think that gap is too small.
Old Dec 21, 2007 | 01:17 PM
benflynn's Avatar
i will give it a look, thanks mike
Old Dec 22, 2007 | 08:06 AM
benflynn's Avatar
i can't find a vac leak for anything, the pwr steering pump is now making a nice lound racket, and someone backed into it lastnight and drove off
i cleaned the iac, seemed to help, but now it idles higher than ever, i guess ill pull the iac housing and clean it
Old Dec 22, 2007 | 12:38 PM
okdiscoguy's Avatar
check/ replace your PVC hoses while you are at it. They can look just fine, but crumble in your hand. Also, make sure you are running 91 or higher fuel.
Also, back to Mike's question about plug wires....
Old Jan 6, 2008 | 09:00 AM
benflynn's Avatar
well, i put 1000 miles on it last weekend, drove all over the SE trying to get away from the drought(a 4 letter word for a kayaker)
did some nice classs 4 rivers and averaged about 16-18mpg, still has a hesitation, but i have yet to replace the dist vac advance
booster is certinly going south, and i am going to pulll the intake back off and make sure she is all sealed up properly, but it is finally acting like a truck w/75k miles, i think it just sat up too long
Jo1175
Jan 20, 2012 07:50 AM
HE_CPT
19
Oct 26, 2010 11:37 PM
skatelove303
Jun 14, 2010 01:31 AM
goldfishy
Mar 13, 2009 12:42 AM
rczar
Jan 7, 2009 07:07 PM
