95 DISCO PUT IN REVERSE PROBLEMS
Old Jul 8, 2008 | 03:59 PM
yankee1919's Avatar
Default 95 DISCO PUT IN REVERSE PROBLEMS
Hello all.
I have a chance to purchase a 95' discovery but the previous owner states in has trouble sometimes to put in reverse.
Is there an electronic switch that might be going bad. I also heard there might be a transmission oil filter that might have to changed?
I believe it has 130k miles on it.
thanks
tony
Old Jul 8, 2008 | 05:00 PM
Default RE: 95 DISCO PUT IN REVERSE PROBLEMS
Tony-slow to engage reverse is a sign that the transmission filter is clogged. Not just on Rovers but almost all cars.
First thing I would do is check the trans fluid level, is it full? What color is the trans fluid? What does it smell like?
Also ask yourself "do I really want to buy a neglected trk?" If he let the transmission get this bad what else is he hiding?
Old Jul 8, 2008 | 06:42 PM
yankee1919's Avatar
Thanks Spike555
Young kid probably thought it was a car he can drive to the ground. I will inquire if he has any other problems.
tony
Old Jul 8, 2008 | 06:48 PM
If you are serious about this trk take it to a mechanic and have them give it a once over, it will cost you around $50.
If you dont want to spend that and are willing to chance it, take it to AutoZoneand have the check engine light codes read, i assume that the CEL is on and post the codes on here.
And just so you know, you MUST use premium gas in a LR.
Old Jul 8, 2008 | 07:27 PM
99LRDisc's Avatar
And for new buyers, even a good looking running truck down the road will need some money put into it. I've learned and read of course. Wonderful trucks if cared for and willing to spend money into. Read as much as you can on the fourms. go to the search and type in key words and read up. Many have been answered and will give you an idea on what your thinking about buying into. Hope to see you more here.
Old Jul 8, 2008 | 07:30 PM
Tony, there are many reasons a tranny won't go into reverse, none of them are good.
Don't even make an offer on it until the owner has it properly fixed or look else where.
djgraham
Jan 9, 2013 06:50 PM
markrperna
Mar 18, 2010 07:13 PM
LuvToDisco
Sep 23, 2009 04:53 PM
theworks001
Dec 8, 2008 09:47 AM
