95 disco wont turn left
Old Feb 7, 2007 | 05:13 PM
4door5g's Avatar
3rd Gear
Default 95 disco wont turn left
hi i have a 95 disco that will not turn to the left it turns to the right all the way but none to the left it will go straight but not any further any one have any clue what needs to be fixed, it happend yesterday after i got stuck. i have lloked under to see if somethings under there and theres nothing binding that i can see please help im ready to burn this thing
Old Feb 7, 2007 | 06:20 PM
geoman's Avatar
Default RE: 95 disco wont turn left
What do you mean this happened after you "got stuck"? The steering system binding in only one direction is an indicator that you have either broken a internal component inside the steering box or you have a seized rod-end (which I've never seen). There is a remote possibility that you crushed the housing on the steering stabilizer from a off-road impact.
Let us know what you find.
Geoman
www.eurotekapg.com
Land Rover Hard Parts delivered to your door --serving the do-it-yourself owner/enthusiast
Old Feb 7, 2007 | 06:30 PM
4door5g's Avatar
3rd Gear
there was no impact i pulled down into some mud and it got stuckafter i pulled it out it stoped turning
Old Feb 7, 2007 | 07:20 PM
Rover steering boxes can fail, I had mine lock up out on the highway when driving home after a long weekend of wheeling. Assuming there is nothing bent, your gear box is probably gone.
If that is the case, here is a good site to buy good guaranteed used boxes at,
http://www.roverlandparts.com/index....TS&Category=89
Mike
ryan884
Mar 16, 2013 08:55 AM
Thatdudeuno1
Mar 11, 2012 11:13 AM
JBEGIN
Aug 9, 2009 11:58 AM
Gomie
Feb 3, 2009 03:16 PM
LordOphidian
May 30, 2006 03:00 PM
