95 discovery auto transmaiison
Old May 29, 2008 | 08:37 PM
lennie5936's Avatar
Default 95 discovery auto transmaiison
Now that I've got the vehicle registered and running:
It appears to stay at an idlerpmof 800-850 in neutral
My running rpm from mph 25-65 keeps leveling off at around 2800 rpms
I expected 2000 to 2100 rpms, whats normal??
Is there a vacum line or valve body attached to the trans. that could create a delay in its shifting ? I sometimes want to fiddle with the gas pedal to prompt it to shift sooner..
Old May 29, 2008 | 09:19 PM
Default RE: 95 discovery auto transmaiison
That is normal.
Your idle when warm should be between 500-800rpm. Remeber that your tach is not 100% accurate.
Old May 29, 2008 | 09:24 PM
roverguy7's Avatar
sounds about right, however there is a kickdown cable of sortsthat hooks up to your throttle linkage
Old May 30, 2008 | 07:41 PM
lennie5936's Avatar
thanks guys, i'm a little more at " pc of mind" with the rpms...........
Benjamin Wright
May 13, 2012 04:40 PM
shanebeardsley
Sep 11, 2011 01:23 PM
catnali
Jun 5, 2011 05:02 PM
Luckesc4vett
Feb 18, 2009 07:54 PM
mge_1
Feb 13, 2009 09:43 PM
