'95 Discovery questions
Old Mar 23, 2006 | 12:51 PM
russ00001's Avatar
Default '95 Discovery questions
I just purchased a '95 discovery with a few minor issues. Here they are. Please help this new new member if you can!
1. Rear cargo dor will not unlock automaticaly. I have to crawl back to pull up on the ****. It locks fine. When I pull up on it, it doesen't seem to be pulling on anything, there seems to be no resistance. The outer handle works fine.
2. Both of the sun roofs will not open!!
3. While sitting at a light I can feel a slight miss. The tach does not drop. I have changed the wires and the plugs. The distributor looks fine.
Old Mar 23, 2006 | 06:12 PM
95roverV8i's Avatar
Default RE: '95 Discovery questions
1. most likely the metal rod came off the unlock mechanism
2. check the Window Control Unit (behind glove box) for a bad point...if its not that probably bad motors (mine has this problem)
3. could be any number of things, possibly mixed up spark plug wires
Old Mar 23, 2006 | 11:17 PM
xb70valkarye's Avatar
When dissassembling the back to get the lock make sure you pull off the sub-woofer part properly, it needs to be disassembled a bit first. I had a similar problem with the reat door where I had to hold up the lock and unlatch it together. The overcenter mechanism was bad and I found a used mechanism on ebay for $35 that took care of the problem. Hope this helps...
TNRover
Jan 23, 2020 08:27 AM
avking
Feb 18, 2009 05:10 PM
Desertdualsport
Oct 16, 2006 11:21 AM
2k2wranglerx
Mar 6, 2006 07:08 PM
Mark Evans
Feb 12, 2006 04:30 AM
