95 Discovery randomly won't start (once a week usually)
Greeting from Hawaii,
I have an 95 disco that decides at the most opportune times to not start. Generally if I swear a lot and leave it alone for about an hour it will usually start up, but it seems to be getting worse and today it wouldn't budge for the whole day. The symptoms are this.
Finally, i found that diagnostic box under my passenger seat, but i don't understand how you would hook it up or plug it into anything.
Thanks for your time
Jason
- turns over no problem
- i smell gas after a while
- i can hear the fuel pump turning on
- once started never stalls or runs rough
- engine runs very smooth
- only has happened once a week or so
- research has told me i own a V8i multi-port fuel injection model
- 145,000 miles
- i've been told to look for a crankshaft position sensor or camshaft sensor, but i'm pretty sure i don't have those on this model
- lots of sensors, O2, fuel temp, coolant temp, air intake, has an ECM, vehicle speed sensor, fuel cut-off switch, speed sensor for fuel mixture.
- when it finally didn't start all day i disconnected the battery-nope
- pulled the ignition fuse-started-coincidence? i don't know.
Jason
r6speed
08-14-2009 06:32 PM
rover
Freelander
08-08-2007 11:28 AM
