96' DI, Open Vacume Lines Normal?!?
While trying to get to know my 96' DI better, I came across 2 vacume lines that don't connect to anything on the top end. They are both located right behind the rear end of the passenger side valve cover, and they're both curved on the ends.
Is this normal?
Is this normal?
All your oil boxes have breather tubes, oil gets hot and the air expands. Breather tubes let the pressure equalize and not blow out seals. Also check your differential/axle breather tubes to make sure they are not clogged. This should be part of your regular maintenance.
amnesia622
Dec 13, 2005 12:27 AM
marlymarl
Jul 28, 2005 12:23 AM
