96 DI won't start
Old Aug 28, 2007 | 02:56 PM
crownaviation's Avatar
Default 96 DI won't start
My 96 DI SD (Man trans) won't start. I have recently replaced fuel filter, plugs, wires etc. Not the problem. Months later I tried to reset the check engine light via the Emission Maint. Reminder (AMR 5551). That reset the light for about 10 miles. Oh well, I am sure the 02 is erratic asI have put 122K on the vehicle. *Back to the little brown maint. reminder box. This box is located on the PAX side lower kick panel. Also located here are several relays (AC/Starter etc.). While I had all of these down, I ended up with a water issue (leak) now these relays and the Emission Maint. reminder do-hickey were soaked and now corroded. Two months of sitting and I got around to replacing the yellow starter relay and now it turns over fine.Fuel psi great, no bad fuses with alarm or others I could find. Fuel shutoff on firewall good, no alarm light etc. I did notice the door locks do not function properly (won't lock automatically anymore) but I have not replaced all the relays in this area that were damaged (green/yellow).
***Will a bad or malfunctioning Emission Maintenence reminder prevent the truck from starting, or inhibit any of the ECU's in any way???? Thanks for helping me with my stupidity!
Disco Alan
Nov 21, 2014 09:21 AM
toad2
Jan 17, 2014 09:19 PM
Mountain State Rover
Jun 29, 2013 02:06 PM
dmatranga
Feb 5, 2013 12:27 AM
vtec2403
Jan 30, 2013 05:27 AM
