96 disco drivers side front window
Old Aug 2, 2005 | 11:27 PM
bruxros's Avatar
Default 96 disco drivers side front window
Window wont roll up.Took door panel off & found a round white plastic piece laying in bottom of door.Any ideas?
Old Aug 4, 2005 | 12:50 AM
duboff's Avatar
Default RE: 96 disco drivers side front window
oh you have another one of those. a common problem. the window regulator needs to be replaced. It can be a diy thing if you have the tools, time. there is a step by step thing in the manual. there is also one on the forum, in the FAQ section. I have heard of the regulator being repaired, but have not found where. the parts can be ordered from roversnorth. The biggest thing is, that it is difficult place to work and is a pain. a friend and a cold one would be of help. the friend would be some one to share the misery. If you do this make sure that you protect the window. I used duct tape, others have used different ways the idea is to get it out of the way so you can remove the regulator. an upholestry tool is a good thing to have. again get the window up and secure it. hope it helps. I have done 2 of them. gottta love a rover. duboff
Old Aug 5, 2005 | 01:54 PM
teamyonex's Avatar
I believe this is a common problem... plastic piece breaks, window gets all crooked, and won't roll up. Get them all replaced if you can as they seem to fail in unison. Cheap part and fix if it's that simple. Good luck.
twoxred
Oct 4, 2021 07:07 AM
aarongregor
Apr 25, 2012 04:59 PM
alphawolfman
Apr 13, 2009 09:09 PM
alphawolfman
Nov 17, 2008 06:34 AM
lionel
Oct 15, 2007 10:53 AM
