Drivers side window problems
Old Nov 16, 2008 | 07:09 PM
alphawolfman's Avatar
Default Drivers side window problems
Took my 2000 Rover to a BoyScouts campout this week-end. I've got the door requlator problem that won't let the window come back up if you let it all the way down. This happened to me once and I got it back up by pushing a towel down inside rubber window channel and over the glass,then using a small pair of king-nosed pliers to lift the glass upward as I pressed the switch.
Anyway,I was driving to campground when I came upon an accident in a curve that had the road shut down. When the officer came back to my truck to tell me what was happening....yep, you guessed it. I hit the switch and let the window all the way down. Got back to camp and tried technique I just described, but with different result. Maybe it had something to do with it being 36 degrees. My drivers side window just shattered like someone had shot it when I put a little pressure on the glass to pull it up.
So, now, I need a replacement glass. [:@]I've seen a couple local shops who will do it for around $300. Is that a normal price? Can I buy the glass and install it? I'm fairly handy with mechanical stuff. What are some thoughts on this? Thanks!
Old Nov 16, 2008 | 07:12 PM
snowdude's Avatar
Default RE: Drivers side window problems
dammm, camping in the middle of november? how fun. driving it back when its this cold must be even funner.
Old Nov 16, 2008 | 07:19 PM
Willie 00D2's Avatar
It is common for the plastic roller that lifts the window to break. When that happens it binds.
Willie
Old Nov 16, 2008 | 07:28 PM
Snowdude, Here in Tenn camping in Nov is great! Probably not quite as cold as it is in Wisconsin.
Was a little cold driving the 22 miles thru the Smokie mountains at 11pm to get back to camp.
Any suggestions on the window replacement??
Old Nov 16, 2008 | 08:01 PM
Call your insurance agent, it will be covered under your glass policy.
Old Nov 17, 2008 | 06:34 AM
Cessna310Guy's Avatar
Alphawolfman, I had my RH front window give me problems last year and I discovered not only the plastic roller giving me issues b/c it was almost completely broke on the regulator but also the motor lost most all of its strength, I did some tinkering to the regulator and put a new motor in and presto, like new again.
twoxred
Oct 4, 2021 07:07 AM
scwkof
Jan 16, 2010 10:28 PM
alphawolfman
Apr 13, 2009 09:09 PM
lionel
Oct 15, 2007 10:53 AM
bruxros
Aug 5, 2005 01:54 PM
