96 Disco misses only when warm
Subscribe
Jun 21, 2007 | 12:32 AM
I have a 96 Disco with 131000 Miles on it it runs great when it is first started and will run good for the first 45 minutes or so. If I then shut it off for a short time to fill gas or something, it will have a intermittent miss upon resart. When it misses it will drop 200 to 300 rpm on the tack it will do this for some time and then clear up. Get a code that says missfire cyl 7. It has new plugs and wires, new fuel filter cleaned the mass airflow sensor,did the seafoam trick both gas tank and induction,. No changes. This thing misses worse the warmer the weather gets. when its cold and rainey it runs like a champ. I have checked alt output, also comp is good, checked the TPS it is good. I am down to the ignition coils or worse sticky valves? but it only misses under power it always idles fine so I am thinking valves are ok. Any suggestions this is very baffling. Tried to take it to one dealer and the said if it wont do it consistantly they would have trouble figuring it out too.
Ron
Reply 0
Jun 21, 2007 | 08:09 AM
RE: 96 Disco misses only when warm
The only thing I can think of is the fuel temp sensor.
Let us know what you find.
Reply 0
Jun 21, 2007 | 08:49 AM
I have the same problem.
I tried the coil pack and it did not fix it.
I am putting in injectors this weekend to see if it helps.
Let me know what yo find out......
Reply 0
Jun 21, 2007 | 09:48 AM
Don't waste your money on injectors, that won't correct it.
Ron, what brand of wires and plugs did you use?
Mike
Reply 0
Jun 21, 2007 | 11:57 PM
Mike
I used NGK V groove plugs and STI wires. But let me make it clear this problem had started before the plugs and wires, they have made it no better or no worse. Today I drove to workfollowed same routine as yesterday short stop at the M/C shop for some parts continued to work. 2 hour meetingand then 40 miles back home. It ran so good it almost makes you believe that next time it will not stummble all over itself, but that is the way this thing is going. I get a couple of good trips and then it gets bad for a while. seems worse in warm weather. What about a bad connection inthis "spider" unit I keep reading abouton some other threads?
Ron
Reply 0
Jun 24, 2007 | 10:23 PM
Mike is Right......
The injectors did not fix the problem......
Now I am really stumped.
Could it be the crank trigger for the ignition system?
I have also replaced the plugs, wires, and coil packs, and none of it made any difference.
Seems to be sensitive to ambient temp. Hotter is worse. ( I live in AZ........)
Mike
Reply 0
Jun 25, 2007 | 02:55 PM
Could this be the VSS?
It is a 5spd Disco, and the miss will happen mainly at low speeds?
Clutch switch is a little flakey to. Any link to retarding the ignition timming or anything?
Mike
Reply 0
Jan 4, 2009 | 10:50 PM
Just had to bring back an old topic in case it may help others. I know its been a long time, but it has been a very busy year. In regards tothe miss on my 96 Disco it turned out to be nothing more than than the vehicle speed sensor. Replaced it andmy discohas not missed a beat since.
Ron
Reply 0
Jan 4, 2009 | 11:17 PM
You may have killed the MAF by cleaning it?
Reply 0
Jan 5, 2009 | 12:22 PM
Quote:
ORIGINAL: Nitro96
Ron
THANK YOU THANK YOU THANK YOU for posting the fix.
Reply 0
Subscribe
