96 Disco Window Issues
Old Jul 11, 2007 | 12:31 PM
rgbeard's Avatar
7th Gear
Default 96 Disco Window Issues
New Disco Owner. (96 Disco SD) Love the forum.
At issue are both the rear windows. Will only actuate up/down after vehicle has been running now for 20 minutes [approx.]. Started weeks after purchase in March but was only about 2 minutes. Has now gotten progressively worse. Front windows work fine.
Any ideas or suggestions.
[IMG]local://upfiles/7010/09EFF6C6F1AB413D97511B5D192E002D.jpg[/IMG]
Old Jul 11, 2007 | 12:42 PM
Landzu's Avatar
Default RE: 96 Disco Window Issues
Its the window relay thats behind the glove box.
Sometime you can pull out and resolder the cold looking spots.
It worked on mine until I went off roading now mines back to 5 mins.
You can get a new power window controler for about $200 from Atlantic British.
Old Jul 11, 2007 | 01:19 PM
DiscoJag's Avatar
RG, nice looking truck, it looks ... just like mine ! I also have a '96 SD. I had the exact same problem with the windows, and it is as Landzu said, the window ECU behind the glovebox. There is a spot where the solder fails. I did the resolder myself, it's not a bad job. I found a beautiful write-up with pictures. If you want, I can dig it up. Not sure if it was this forum or another LR forum I'm on that had it posted, but this is a common problem - like so many others - but once you get the bugs out you're good to go.
Old Jul 11, 2007 | 01:34 PM
DiscoJag's Avatar
Rg, Here's the link -
http://www.discoweb.org/window/index.htm
It's not quite a easy as it sounds in this write-up, but it's not too bad. Mine was actually bad in exactly the same place asin here, the same one solder joint. Just flow a little solder on there and it was fine. The tricky part is getting the circuit board in and out.
Old Jul 11, 2007 | 01:52 PM
Landzu's Avatar
What got me was the nut in the back .
I thing that link will help alot of people !!!
Good going Disco Jag !!!!!!!!!!!!!!!
Old Oct 2, 2007 | 07:39 PM
Landzu's Avatar
Window link is in this post.
Old Oct 3, 2007 | 06:51 AM
Landzu's Avatar
ORIGINAL: Landzu
[sm=smiley20.gif]
twoxred
Oct 4, 2021 07:07 AM
RedAustinIX
Aug 10, 2020 11:43 PM
jw928
Feb 6, 2010 06:51 PM
PIROLOGISTS
May 25, 2008 05:43 PM
