96 Discovery mystery sound
Old Sep 3, 2009 | 02:26 PM
icautious's Avatar
3rd Gear
Default 96 Discovery mystery sound
I have a 1996 Discovery that runs and drives fine but makes a roaring noise when I let off the gas pedal. Does anyone have any ideas what this could be?
Old Sep 3, 2009 | 02:34 PM
98roverguy's Avatar
Probably your fan/fan clutch. I don't know the severity, but I don't think it's anything to worry about.
Old Sep 3, 2009 | 02:43 PM
icautious's Avatar
3rd Gear
Default Its kinda loud
I don't know but the noise is pretty loud. It almost sounds l.ike a jake brake on a big truck
Old Sep 3, 2009 | 04:43 PM
tex599's Avatar
Check your rotoflex on the rear driveshaft, look for cracks/tears, etc. . Mine was doing the same thing. Buy the OEM disc, $60, aftermarkets do not last that long. Almost positive that is it. You can remove the rear shaft, lock the CDL and test. Might as well redo the ujoint while you have it off.
Old Sep 3, 2009 | 09:32 PM
icautious's Avatar
3rd Gear
I thought that might be it. I checked my local autozone and advance auto parts and they did not show that part, where is a good place for parts?
Old Sep 3, 2009 | 09:53 PM
For that you want to either get it at the dealer or at www.atlanticbritish.com
It is called a roto flex also known as a flex coupler.
Old Sep 4, 2009 | 11:16 AM
leadfoot's Avatar
If the roto flex looks good, and even if it doesn't, check the oil level on the transfer case. If it gets low it makes a roaring sound under deaceleration.
BluePointDisco
Jul 11, 2017 11:44 PM
bubba george
Aug 19, 2013 08:22 PM
MrMoneyBags
Jul 21, 2013 02:40 PM
kevlor80
Mar 13, 2012 04:19 PM
mvjimenez
Jun 12, 2010 10:25 AM
