96 discovery washing under the hood?
Old Sep 20, 2007 | 06:27 PM
tym2brn's Avatar
8th Gear
Default 96 discovery washing under the hood?
My newly purchased 96 discovery is pretty grungy under the hood....any problems using a engine cleaner an hosing the engine compartment....also whats the best grade oil to run in the
engine?.......thanks mark
Old Sep 20, 2007 | 08:23 PM
okdiscoguy's Avatar
Default RE: 96 discovery washing under the hood?
Watch out for the ecu (passenger side near the firewall) and the coil pack (behind the intake where plug wires go) and you should be ok. Just be ready. Rovers tend to leak, and there may be some gunk holding a leak back. Also make sure it is cold.
By grade, do you mean weight? where do you live? Your owner's manual has suggestions based on temp ranges. That said, I live in Oklahoma and I run the equivalent of 10W30. (It's a full synthetic racing oil). Most run 10W30 in the winter and 10W40 in the summer. Make sure and use a good quality filter like a K&N or Mobile 1 and change it regularly..
Kandow
Nov 2, 2011 07:39 AM
Disco-Nate
Jul 8, 2010 03:55 PM
Autogeek
Detailing
Oct 13, 2009 10:12 AM
Chrisinhouston
Mar 4, 2008 05:08 PM
loic
Feb 3, 2008 09:51 AM
