washing the truck engine light CODE RESULTS
Old Feb 2, 2008 | 01:04 PM
loic's Avatar
Default washing the truck engine light CODE RESULTS
I just washed the truck and the engine compartment, after driving off the car wash, the truck start to run a little rough then normal, then a little rough again at slow speed then normal again, also the Service engine soon light flashed 3 times then went on steady then a few minutes later flashes again 3 times and steady again...
is it just something that got wet and will go away as it dry or I'm out of luck ?
Old Feb 2, 2008 | 01:39 PM
Default RE: after washing the truck engine light
Is it driving better now after it has had a chance to dry out?
If it is doing better, the light may reset it self, if not, go by your local auto parts store and have them read your codes for free, then get back to us with your 4 digit fault code numbers.
By the way, do you still have your original plug wires, if so, that may be the problem cause for the most parts D2's take water real well.
Old Feb 2, 2008 | 01:46 PM
Luv2Disco's Avatar
If your truck is running normally again and your Service Engine Light is STEADY (not Flashing) I would continue to drive it for a couple days and wait for the light to go out by itself. It seems obvious by gettingsomething wet you probably had a temporary issue and threw a code. If it doesn't go off by itself you'll have to get your SES light turned off by someone with a code reader after you see what code(s) you have/had. Contrary to what some will tell you, your SES lightmay reset on its own if the problem resolves itself. Good luck.
Old Feb 2, 2008 | 01:54 PM
loic's Avatar
ok, I'm gonna wait a little for it to dry then I'll drive it and see.
actually I was thinking of buying a scanner , is this a good unit ?
Equus OBD II Code Reader
Part Number: 3100
Old Feb 2, 2008 | 01:55 PM
Camdisco24's Avatar
I have heard of this happening when people steam clean the engine. For the most part the light just went out after a few miles of driving. There could be something knocked loose if you used a pressure washer, but I doubt it. Like mike said, give it time to fully dry out and if it doesnt go off by then, go get the codes.
loic's Avatar
as far as the plug, I have no clue as I bought the truck used 18 months ago..
Old Feb 2, 2008 | 03:10 PM
Power scrubbing and steam cleaning are 2 different things, D2, normally take a power scrub well, I do mine at least once a month or after a hard run. Steam cleaning can cause wire connection issues.
Go get you codes read, if the ECU locked a hard fault it won't go away by it self. Get back to us with the fault number.
Old Feb 2, 2008 | 07:43 PM
loic's Avatar
ok I bought a scaner and here are the results:
P1300
Catalysr damaging misfire multiple cylinders
drive cycle
C: signal out of range
-Above maximum
P1590
Rough road signal
implausible drive cycle
A: signal implausible
P0303
Cylinder 3 misfire detected
P0305
Cylinder 5 misfire detected
P0307 cylinder 7 misfire detected
P0300
random misfire detected
P0134
02 circuit no activity detected
(bank 1, sensor 1)
it's rough/vibrating at idle speed only. then after I drive a litle it doesn't do it..
Old Feb 2, 2008 | 10:22 PM
You need plugs and wires. These guys recommend Magnacor wires and Bosch Platinum plugs, Iuse either Denso or NGK Iridium plugs.
http://www.ngksparkplugs.com/
http://www.boschautoparts.com/Produc...lugs/Platinum4
You most likely got water inside one or more of your spark plug wire boots where it connects to the spark plug.
Old Feb 3, 2008 | 09:51 AM
You might want to give me a call, your truck has issues that can't have all come from washing the engine.
If you get a chance call today before the game at 303-862-7680 in Colorado.
Fmb Choppers Fmb Choppers
Oct 10, 2018 08:43 PM
buick215
Jul 29, 2013 12:49 PM
Autogeek
Detailing
Oct 13, 2009 10:12 AM
Chrisinhouston
Mar 4, 2008 05:08 PM
tym2brn
Sep 20, 2007 08:23 PM
