97 Disco fuel pump
Old Feb 25, 2006 | 04:09 PM
mikemeyer0's Avatar
Default RE: 97 Disco fuel pump
ORIGINAL: MilitantGrunt
Buy a junkyard pump or new one, which ever, go to a private mechanic, with the cost of the pump i had mine installed for around 350.
A new pump in the Disco's are easy to install, if you were able to get the screws holding the plate cover on and the ring that holds the pump in, then you should be able to change the pump. I can do my fuel pump change in less than 30 minutes start to finish and thats the new $80 pump.
Old Feb 25, 2006 | 09:01 PM
adowgiert's Avatar
The actual fuel pump swap only took a few minutes but it took me what felt like all day to get the screws out. First they were all rusted and then the heads were all stripped out. Some rust remover and a bent up flathead screwdriver later, the little bastards came out and the rest was cake.
Old Apr 4, 2006 | 12:14 AM
dpeek's Avatar
4th Gear
Wow, thank you mikemeyer0 so much. I just bought my 96 discovery last tuesday and the pump went out on sat. I was afraid i was going to have to pay $300 for a new fuel pump assembly but your pump swap worked like a charm. The only problem i had was removing the tube from the old pump, but finished the whole thing in about 35 minutes in the Wal-mart parking lot with minimal tools. Thank You.
Old Apr 4, 2006 | 02:29 AM
mikemeyer0's Avatar
ORIGINAL: dpeek
Your welcome, I did one in a auto store parking lot in Moab. Quick and easy actually. And Cheap. Did you use hose clamps on the hose that was hard to remove, I did just in case.
Old Apr 14, 2006 | 12:46 AM
dpeek's Avatar
4th Gear
Yeah, i did use the hose clamp. Have another question though. WHat kind of fuel filter did you use pre-pump filter did you use, mine didnt come with one and im not sure if there is a generic or a specific one to get? Thanks
Old Apr 14, 2006 | 03:51 PM
ghazz's Avatar
We do it in the shop all the time but its easily done by yourself and saves a hunk of cash.
Old Nov 27, 2008 | 02:16 PM
mrsbntn's Avatar
mike I got the pump that you said get & it works just it seems like my diso is flooding can you give me any insight on whats happenning
Travelor
Sep 24, 2015 06:11 PM
coldstart
Mar 9, 2014 07:08 PM
JumPeR04
Apr 7, 2011 09:52 PM
JumPeR04
Apr 1, 2011 04:15 PM
