97 disco won't start when it gets hot.
Old Jul 11, 2009 | 02:34 PM
patrick in pa's Avatar
7th Gear
Default 97 disco won't start when it gets hot.
97 disco won't start when it gets hot. the battery is strong and once it cools down it starts right up. any ideas?
Old Jul 11, 2009 | 03:16 PM
How many miles on the engine? If the engine turns over OK, then start with a fuel filter, then a fuel pump relay, then check the fuel pressure when hot and try to start.
Old Jul 11, 2009 | 03:37 PM
7th Gear
Default starting problem
the problem is the starter doesn't engage. can hear something behind the glove box clicking but nothing under the hood. then when it cools down it starts normal.
Old Jul 11, 2009 | 03:39 PM
7th Gear
there is 183000 miles
Old Jul 13, 2009 | 07:24 PM
OlliesRover's Avatar
6th Gear
I am haveing the same problem 98 Disco 1 I turn the key and absolutely nothing happens. Not one sound. It seems like the ignition or no power getting to the starter.
Old Jul 13, 2009 | 09:37 PM
It is the starter going bad, these starters get "hot spots" on them and when it stops on that spot it wont turn over, bump the key a couple of times and she starts just fine.
Old Jul 13, 2009 | 11:50 PM
mattrickman's Avatar
This could also be a problem with the fuel temp sensor.
http://www.roverparts.com/TechTips/h...t_problems.cfm
I had this same problem and I ended up with a bad fuel pump.
The problem used to be very intermittent, then got progressively worse with other problems. New Fuel Pump and New Fuel Temp Sensor fixed this (and many other) problems.
Cocobills
May 11, 2013 10:31 PM
fastrx7man
Jun 21, 2012 10:31 AM
freelanderfan
Sep 25, 2011 04:58 PM
tripledbucks
Dec 2, 2009 07:07 PM
