97 Discovery
Old Jun 5, 2010 | 04:19 PM
Tymc007's Avatar
6th Gear
Default 97 Discovery
My 97 discovery is wining a high pitch sound when ignition is on. I also can't take key out of ignition. Help?
Old Jun 5, 2010 | 05:22 PM
Rovin4life's Avatar
jiggle the stearing wheel to release the steering lock to release the key. lube up the lock and get it rebuilt by a locksmith.
Old Jun 5, 2010 | 06:43 PM
Sounds like a bad ignition switch and the starter is not releasing because the key is not kicking back to the "II" position.
Old Jun 5, 2010 | 07:10 PM
Tymc007's Avatar
6th Gear
Default Tymc007
Ignition is ringing even in on position prior to starting. Steering wheel doesn't lock. Can I disconect any wire to stop ringing?
Old Jun 5, 2010 | 07:14 PM
You can pop the cover off of the steering column and unplug the ignition switch.
Old Jun 5, 2010 | 07:22 PM
Tymc007's Avatar
6th Gear
Default Tymc007
High pitch ringing while running and when ignition switch is in on position prior to engaging starter
Old Jun 5, 2010 | 07:26 PM
See my other reply.
Old Jun 5, 2010 | 07:29 PM
Tymc007's Avatar
6th Gear
Default Tymc007
Unplugged weird plastic plug on ignition to no avail
Maybee wrong wire?
Old Jun 5, 2010 | 07:31 PM
Tymc007's Avatar
6th Gear
Default iginition
Wish I could upload pic. ,new member
Old Jun 5, 2010 | 07:35 PM
Unhook the battery.
I have no idea what it could be.
