97 SE7 Oil Leak??? Service Engine???
Old Sep 12, 2008 | 01:26 PM
bsmullinax's Avatar
6th Gear
Default 97 SE7 Oil Leak??? Service Engine???
I have an oil leak seems to be coming from Oil Filter area. just purchased it. one owner 102,000 miles. Service engine light is own. any suggestions... comments... or things to watch out for in the Land Rover Discovery World!
Old Sep 12, 2008 | 01:50 PM
Default RE: 97 SE7 Oil Leak??? Service Engine???
The oil leak is your oil pressure sending unit. About $15 at AutoZone. You can replace it yourself. It is directly above the oil filter.
Is your red Service Engine Soon light on or the amber Check Engine light on? Makes a big difference.
Things to look out for, you MUST use premium gas. With DI's you will have ABS problems. Not worth fixing in my humble opinion. When you do a tuen up you must use either Land Rover plug wires or better yet Magnecor plug wires.
Not much else, do not use a K&N air filter, use premium gas. Change the fluids in everything and just enjoy it.
Old Sep 12, 2008 | 02:06 PM
bsmullinax's Avatar
6th Gear
it is the service engine light.... not the Check Engine. i am going to give it a tune up. i got the list. 60k or should i do the 120K????
Old Sep 12, 2008 | 02:13 PM
They are the same service, just follow my list that has been posted on this site many times to the letter.
As for the service light, there is a relay in the passengers kick panel, orange in color with a Rover emblym on it. In the midle of the emblym is a pin hole, use a paper clip, insert it into the relay with the key in the 2nd position and short the relay.
That should take care of that problem.
Old Sep 12, 2008 | 02:33 PM
bsmullinax's Avatar
6th Gear
were can i find that list?
Old Sep 12, 2008 | 02:50 PM
okdiscoguy's Avatar
ORIGINAL: bsmullinax
This is the parts list for a 60,000 mile service the way I do it.
1 Oil filter , K&N 3001
1 Air filter
1 Transmission filter kit
6 Qts of engine oil
12 Qts of ATF
7 Qts of 80/90W gear oil
2 Qts of Brake fluid
2 Qts of synthetic Power steering fluid ( ATF for D1)
2 Gallons of OAT, orange coolant (whatever you have in it for a D1)
1 Bottle of Lucas Power Steering additive ( Not for D1)
1 Bottle of Lucas Transsmission additive
1 Can of Spray Carb Spray
1 Can Of Brake cleaner
8 Spark Plugs, I use Bosch Platium Plus 4's
1 Set of Magnacor 8mm plug wires
1 Serpentine belt if not yet replaced
2 Bottles of SeaFoam
60,000 Mile Service
Bleed the brakes
Flush and change the power steering fluid adding one bottle of additive
Service the tranny adding one bottle of additive
Flush the coolant system
Do an engine flush before changing the oil
Do an induction cleaning
Clean the throttle body
Add fuel additive to full gas tank
Change both od the diffs fluid
Change the t/case oil
Replace the plugs and wires
Replace the air filter
Lube all the drive shaft grease fitting including the 2 slip shafts
Do full inspection of brakes, hoses, bushings etc.
Hopefully I didn't leave anything out.
Mike
< Message edited by Disco Mike 1/21/2007 9:20:50 AM >
sfortier99
Dec 28, 2019 11:35 AM
Rufflyer
Mar 22, 2015 10:13 AM
salve7
Other
Nov 1, 2010 04:35 PM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
hollis
Oct 10, 2007 04:24 PM
