98 disco ,hit bump shaky front end
Old May 5, 2009 | 08:54 PM
nate's Avatar
4th Gear
Default shaky front end
I hope you get this thread before you spend a whole lot more cash. I have a 96 disco that put me thru the same crazy thing, I finally put on a stabilizer shock made by "old man emu" and it solved the problem. I spent piles of cash and am still kicking myself for this, these rovers will drive a normal person nuts so it's good to gt as much info as you can before you spend. Nate
Old May 6, 2009 | 07:18 AM
antichrist's Avatar
Originally Posted by texmanmoore
i was hoping you would respond , yes i will check into rebuild kit , Im assuming the rebuild kit is nothing more than a new bushing/ bearing and shims. Is it possible i need to go deeper and do the bigger repair and replace the swivel ***** , Im wondering how big of a job that is , I want to fix this problem once and for all , so far my own labor is cheaper than anyting i can afford. I do wish however there was some good step by step instruction for replacing the swivel ***** along with new bushing/ bearings.
The kit typically comes with all the seals and gaskets from the large swivel seal on out to the flange gasket.
It's not a huge job, just tedious. The factory manual gives step by step (that's what RAVE is, only electronic format). The Haynes manual does as well.
Removing shims is just a temporary fix. You shouldn't need new swivel *****, they aren't a wearing item.
NO!
You didn't solve the problem, you masked the problem.
I see this all the time on the various forums, "I installed a new stabilizer, problem solved."
Land Rovers do not need a stabilizer to prevent steering wobble, that is NOT the purpose of a steering stabilizer.
Old May 7, 2009 | 11:41 AM
texmanmoore's Avatar
Default responce Tom Rowe
I really feel like im getting the root cause , great information to any one having this problem , thx again
redmanxi
Nov 17, 2014 05:05 AM
wheelgarage
May 23, 2012 07:43 PM
CANAMDiscovery
Apr 2, 2012 04:20 PM
RROJ
Nov 20, 2010 01:21 PM
barnwell
Sep 21, 2007 08:20 AM
