98 Disco (Purge Valve p1448), odometer stopped working and...
Old Jan 26, 2010 | 09:03 AM
masism's Avatar
Default 98 Disco (Purge Valve p1448), odometer stopped working and...
Well I thought it would be atleast a month before I would be back to the forums, but last night while driving home - the odometer randomnly stopped working, so I automatically thought alternator. Then I filled up on gas and about 10 mins later, check engine light comes on, drive 10 mins more and battery light comes on. So I get the truck home, which is always good, pull the codes and I have only one p1448 (evaporative loss control system - Major leak (Driving Cycle C). So that is where I am at. And looking for some diagnosing.
98 Disco 142m on it, most recent change was the fuel pump - about 2 weeks before this. Let me know if you need to know anything else.
Thanks all.
Old Jan 26, 2010 | 07:07 PM
Your odometer is mechanincal, it does not require electricity to work.
Unhook the speedo cable from the transmission, hook up a drill to it, lock the trigger and see if the speedo and OD work.
If yes speedo but no OD then you need a new OD head, if non work you need a new speedo cable.
tsuyoi
Sep 22, 2020 10:37 AM
austinlandroverbill
Apr 1, 2015 06:26 PM
Jared9220
Jan 28, 2013 08:23 AM
Brisket
Aug 10, 2011 07:49 PM
Adsan1280
Jul 12, 2011 11:02 AM
