Are '98 Disco Series 1 Front and Rear Diffs Interchangeable?
Old Feb 23, 2010 | 06:10 AM
aussiedisco's Avatar
Default Are '98 Disco Series 1 Front and Rear Diffs Interchangeable?
Hi everyone. Hopefully someone can answer my question. I have been unable to find a thread with the answer.
I have a '98 Discovery auto Series 1. The diffs both have 4 bolt flanges.
Are the diffs interchangeable?
The rear diff whines like crazy and has had water in it. I am able to get a 4 bolt used front diff and I am wondering if I can bolt it straight into the rear axle housing.
Your input would be greatly appreciated.
Thanks.
Bob.
Old Feb 23, 2010 | 07:36 AM
WARWAGON's Avatar
Yes you can use front/rear or even a series II front/rear. If it has a 3 bolt flange just swap the flanges. The flanges come right off. You will notice one is longer than the other....take a magnet and pull the spacer out from under the flange swap over and your all good. I can't remember right now but there are different length studs on the housings from series I to series II. I just put all longs in my front and rear housings. I changed so many diffs in my 95 DI and the 92LWB I can't remember what was what anymore. You can also use D-90 or classic diffs. Just dont use the real early classic diffs. They only have 11 spline axles. I keep using high milage diffs as repacements and they don't last to long. One day i'll get a locker and that will be over. For now I take what I can get!
grandkodiak
Mar 21, 2014 09:07 AM
geek_IM
Dec 15, 2013 11:27 AM
atancreti
Aug 17, 2011 10:24 PM
MyIQisLow
Aug 15, 2011 07:46 PM
tshah209
May 21, 2011 08:36 PM
