98 Disco won't start
Worked fine yesterday and won't start today. Won't even turn over. With the key in the ignition there is a ticking noise coming from under the glove box. I tried taking it out of park, then back in, and it would then crank but not start. Also, while trying to start it when it would not crank, if you quickly push the accelerator to the floor it will start to crank. The ticking continues throughout all of this.
I replaced the crank shaft sensor last year.
Any ideas before I get the pros involved?
Check out this thread of mine. May help, may not, but maybe some of the symptoms and solutions will help you. https://landroverforums.com/forum/sh...ad.php?t=19583
Check all your connections between the starter and battery. Also check all of your grounds between the battery and starter. If those are all good, I agree with spike, probably the starter. Although it sounds like you have more than one problem.
