98 Discovery won't start
Old Mar 18, 2010 | 09:53 PM
happyD1owner's Avatar
Default 98 Discovery won't start
While driving on the highway today the abs and srs lights came on, a few minutes later the speedometer quit, and it started running rough. When I put the signal lights on to change lanes it was as if I shut it off. Letting go of the signal light it ran smooth again. WE limped into our destination which is 150 miles from the nearest land rover dealer. When we went out to start it later. It just clicked like a bad solenoid or low battery, however the lights are still bright. It will be towed to a garage tomorrow but I would like an idea to what the problem is so they can be pointed in the right direction.
Thanks for any help
By the way we have only had it 3 weeks, looked and ran like it just came from the showroom.
Old Mar 18, 2010 | 10:58 PM
Long Haul's Avatar
Sounds like a fuse block or alternater problem. I'd have them checked out
Old Mar 18, 2010 | 11:36 PM
ljdiscovery's Avatar
check you linkable fuses in the fuse box just behind the battery. Also check for a loose ground wire on the back of the alternator, they have a habit of coming loose. Phil
Old Mar 19, 2010 | 08:54 AM
okdiscoguy's Avatar
have your battery and then alternator tested.
If the battery went, it will be a dead short, and the alt won't be able to keep up.
If the alt. went, the battery won't hold enough charge. You did not have enough voltage, that is why it died when you turned on your signal.
Start with the easy things, then look into wiring.
Old Mar 20, 2010 | 11:26 AM
Default 98 discovery wouldn't start.
Just a thank you to all you guys who gave advice on our 98 discovery not starting etc. The previous owner had a new alternator installed and the shop mechanic who did it put the belts on wrong. He had them going over the top of the pulley so it was barely touching on it. When the alternator was under load the belt would slip and not charge the battery. The battery also needed replacing, runs like a top now. Total bill for new battery and having the belt put on right was only $207.00 which I thought was good.
Thanks again for the advice you guys were right on.
Old Mar 20, 2010 | 05:09 PM
Danny Lee 97 Disco's Avatar
Glad to hear you got it going without major issues.
Disco Alan
Nov 21, 2014 09:21 AM
toad2
Jan 17, 2014 09:19 PM
Mountain State Rover
Jun 29, 2013 02:06 PM
dmatranga
Feb 5, 2013 12:27 AM
vtec2403
Jan 30, 2013 05:27 AM
