Is a 99-02 RR engine swappable into '03 Disco?
Old Jan 4, 2011 | 02:15 PM
Bryan H's Avatar
Default Is a 99-02 RR engine swappable into '03 Disco?
Wondering if the 1999 - 2002 Range Rover 4.6 L is swappable into a 2003 Disco? Thanks for any help.
Old Jan 4, 2011 | 02:18 PM
As long as the replacement engine has secondary air, there are only a couple things to switch over, one, if I remember right would be the flex plate.
Old Jan 4, 2011 | 02:35 PM
Bryan H's Avatar
The flex plate would be easy enough Assuming the holes line up with the crank bolts. According to their website, Roverland has an '02 RR 4.6 with SA, so I'm trying to figure out if that will work. I'll also contact the two gentlemen that you mentioned in my other thread that you responded to. Thx Mike.
Old Jan 4, 2011 | 05:26 PM
Bryan H's Avatar
Roverland Parts guy was saying that the oil pump is different on the RR motor. I tried to get him to explain what is different and why it would matter since, at least on the Disco, the pump is integral with the timing cover and as long as the RR has it's own pump that is also part of the front cover, it should matter if it's different (unless it rotates backwards or something and could'nt be used with a Disco serpentine system - to me, they look the same). We were talking via chat on their website, and he couldn't really explain it. Anyone have insight?
Old Jan 4, 2011 | 05:51 PM
NiteTrain's Avatar
different from a '03 disco oil pump can only be a good thing lol
Old Jan 4, 2011 | 05:53 PM
Bryan H's Avatar
I second that. ; )
But honestly, the engines look identical to me.
Turnsblue
Jan 26, 2013 01:42 PM
sadain
May 3, 2012 09:40 PM
wanjman
Apr 27, 2012 08:58 AM
meltdowndave
Feb 12, 2010 04:02 PM
bmwrovers
Sep 19, 2009 06:30 PM
